Getting started
Getting Started
Get an API Key:
Make API Calls:
Authentication:
Field | Type | Required | Description | |
Yes | The unique identifier of the UAV. | |
Yes | Latitude in decimal degrees. | |
Yes | Longitude in decimal degrees. | |
Yes | Height of the UAV in meters, based on GPS altitude AMSL. | |
altitudeAccuracy |
No | Accuracy level of the altitude coordinate in meters. | |
accuracy |
No | Accuracy level of the latitude and longitude coordinates in meters. | |
callSign |
No | UAV call-sign. | |
groundSpeed |
No | Current ground speed of the UAV, specified in meters per second. | |
No | Direction of travel, specified in degrees counting clockwise relative to the true north. | |
No | The current status of the UAV. Allowable values: INACTIVE , AIRBORNE , GROUNDED . |
lastUpdate |
Yes | The time of the event in seconds since epoch at UTC-0. | |
turnRate |
float |
No | Turn rate in degrees per second. | |
verticalRate |
Yes | The unique identifier of the beacon. | |
Yes | Height of the beacon in meters, based on GPS altitude AMSL. | |
altitudeAccuracy |
accuracy |
callSign |
No | Beacon call-sign, available only if the pilot has a public profile. | |
groundSpeed |
Yes | Current ground speed of the beacon, specified in meters per second. | |
Yes | Direction of travel, specified in degrees counting clockwise relative to the true north. | |
No | The current status of the beacon. Allowable values: INACTIVE , AIRBORNE , GROUNDED . |
lastUpdate |
turnRate |
float |
verticalRate |
No | Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent. | |
beaconType |
No | The type of the beacon. Allowable values: UNKNOWN , GLIDER , PARA_GLIDER , HAND_GLIDER , HELICOPTER , UAV , etc. |
transponderType |
No | The type of transponder broadcasting the position. Allowable values: ADS-BI , FLARM , ADS-B , etc. |
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
lat |
lng |
alt_min |
alt_max |
rad |
Endpoint: POST /uav
Description:
groundSpeed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
rad |
return_grounded_traffic |
boolean |
Example POST Request:
or visit our website.
Disclaimer
