Getting started
Getting Started
  1. Get an API Key:
  2. Make API Calls:
  3. Authentication:
Field Type Required Description Constraints
id string Yes The unique identifier of the UAV. Max length: 15 characters
latitude double Yes Latitude in decimal degrees. Range: -90 to 90
longitude double Yes Longitude in decimal degrees. Range: -180 to 180
altitude int Yes Height of the UAV in meters, based on GPS altitude AMSL.
altitudeAccuracy int No Accuracy level of the altitude coordinate in meters.
callSign string No UAV call-sign.
groundSpeed int No Current ground speed of the UAV, specified in meters per second.
lastUpdate long Yes The time of the event in seconds since epoch at UTC-0.
turnRate float No Turn rate in degrees per second.
verticalRate int No Vertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent.
callSign string No Beacon call-sign, available only if the pilot has a public profile.
groundSpeed int Yes Current ground speed of the beacon, specified in meters per second.
beaconType string No The type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, etc.
transponderType string No The type of transponder broadcasting the position. Allowable values: ADS-BI, FLARM, ADS-B, etc.
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
Endpoint: POST /uav
Description:
Example POST Request:
Disclaimer
