Getting started
Getting Started
  1. Get an API Key:
  2. Make API Calls:
  3. Authentication:
FieldTypeRequiredDescriptionConstraints
idstringYesThe unique identifier of the UAV.Max length: 15 characters
latitudedoubleYesLatitude in decimal degrees.Range: -90 to 90
longitudedoubleYesLongitude in decimal degrees.Range: -180 to 180
altitudeintYesHeight of the UAV in meters, based on GPS altitude AMSL.
altitudeAccuracyintNoAccuracy level of the altitude coordinate in meters.
accuracyintNoAccuracy level of the latitude and longitude coordinates in meters.
callSignstringNoUAV call-sign.
groundSpeedintNoCurrent ground speed of the UAV, specified in meters per second.
courseintNoDirection of travel, specified in degrees counting clockwise relative to the true north.
statusstringNoThe current status of the UAV. Allowable values: INACTIVE, AIRBORNE, GROUNDED.
lastUpdatelongYesThe time of the event in seconds since epoch at UTC-0.
turnRatefloatNoTurn rate in degrees per second.
verticalRateintNoVertical rate in meters per second. A positive value indicates climbing, a negative value indicates descent.
idstringYesThe unique identifier of the beacon.
altitudeintYesHeight of the beacon in meters, based on GPS altitude AMSL.
callSignstringNoBeacon call-sign, available only if the pilot has a public profile.
groundSpeedintYesCurrent ground speed of the beacon, specified in meters per second.
courseintYesDirection of travel, specified in degrees counting clockwise relative to the true north.
statusstringNoThe current status of the beacon. Allowable values: INACTIVE, AIRBORNE, GROUNDED.
beaconTypestringNoThe type of the beacon. Allowable values: UNKNOWN, GLIDER, PARA_GLIDER, HAND_GLIDER, HELICOPTER, UAV, etc.
transponderTypestringNoThe type of transponder broadcasting the position. Allowable values: ADS-BI, FLARM, ADS-B, etc.
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
        "latitude": 48.97128,
        "longitude": 2.56328,
        "call_sign": "PTN32P",
        "last_update": 1733412792,
        "altitude": 526,
        "vertical_rate": -4,
        "course": 266,
        "ground_speed": 72,
        "turn_rate": 0.16,
        "id": "3CE997"
Endpoint: POST /uav
Description:
return_grounded_traffic
boolean
Additional Noquery IncludeParameters grounded beacons ifwhen show_nearby_traffic = true.true:
false
ParameterTypeRequiredDescriptionDefault
rad int No Radius distance in meters from all UAV reference point if show_nearby_traffic = true (maximum: 20000 meters). 10,00010000
return_grounded_trafficbooleanNoInclude grounded beacons.false
Example POST Request:
Similar response as ExampleGet ResponseNearby Aircraft: will be returned.
    "id": "XYZ789",
    "latitude": 48.859,
    "longitude": 2.293,
    "altitude": 1500,
Disclaimer
