Getting started
Getting Started
  1. Get an API Key:
  2. Make API Calls:
  3. Authentication:
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
latitudelat double Yes Latitude in decimal degrees (4 decimal precision). N/A
longitudelng double Yes Longitude in decimal degrees (4 decimal precision). N/A
altitude_minalt_min int No Filter all aircraft below the given altitude in meters. Zero means 'unused'. 0
altitude_maxalt_max int No Filter all aircraft above the given altitude in meters. Zero means 'unused'. 0
radiusrad int No Radius in meters from the reference point (maximum: 20,000 meters). 10,000
        "id": "ABC123",
    "latitude": 48.859,86584,
        "longitude": 2.293,63723,
        "altitude": 1500,10554,
        "id": "DEF456"494105"
        "latitude": 48.860,97128,
        "longitude": 2.295,56328,
        "call_sign": "PTN32P",
        "last_update": 1733412792,
        "altitude": 2000,526,
        "vertical_rate": -4,
        "course": 266,
        "ground_speed": 72,
        "turn_rate": 0.16,
        "id": "3CE997"
Endpoint: POST /uav
Description:
PublishPublishes theone UAV’sor position,many altitude,UAV and flight statusposition to the SafeSky platformplatform. whileOptionally, retrievingit's returning a list of nearby trafficaircraft datafor each UAV position within the specified radius. By default, the searcha radius is 10,000 meters, with a maximum of 20,00010000 meters.
radiusreturn_nearby_trafficbooleanNoReturn information about aircraft traffic within proximity of the UAV positions.false
return_grounded_trafficbooleanNoInclude grounded beacons if show_nearby_traffic = true.false
rad int No Radius distance in meters from theall UAV reference point if show_nearby_traffic = true (maximum: 20,00020000 meters). 10,000
        "latitude": 48.8588,50.69378,
        "longitude": 2.2943,4.39201,
        "altitude": 1200,
  "groundSpeed": 30,
  "course": 180,
  "status"call_sign": "AIRBORNE"FlyingFrog"
    "id": "XYZ789",
    "latitude": 48.859,
    "longitude": 2.293,
    "altitude": 1500,
Disclaimer
