Getting started
Getting Started
Get an API Key:
Make API Calls:
Authentication:
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
lat |
lng |
alt_min |
alt_max |
rad |
"latitude": 48.97128,
"longitude": 2.56328,
"call_sign": "PTN32P",
"last_update": 1733412792,
"altitude": 526,
"vertical_rate": -4,
"course": 266,
"ground_speed": 72,
"turn_rate": 0.16,
"id": "3CE997"
Endpoint: POST /uav
Description:
groundSpeed |
alt_min |
alt_max |
return_nearby_traffic |
boolean |
return_grounded_traffic |
boolean |
No | Include grounded beacons if show_nearby_traffic = true. | false |
rad |
No | Radius distance in meters from all UAV reference point if show_nearby_traffic = true (maximum: 20000 meters). | 10,000 |
"id": "XYZ789",
"latitude": 48.859,
"longitude": 2.293,
"altitude": 1500,
or visit our website.
Disclaimer
