Getting started
Getting Started
Get an API Key:
Make API Calls:
Authentication:
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
altitude_min |
altitude_max |
radius |
"id": "ABC123",
"latitude": 48.859,
"longitude": 2.293,
"altitude": 1500,
"status": "AIRBORNE"
"id": "DEF456",
"latitude": 48.860,
"longitude": 2.295,
"altitude": 2000,
Endpoint: POST /uav
Description:
Publish the UAV’s position, altitude, and flight status to the SafeSky platform while retrieving nearby traffic data within the specified radius. By default, the search radius is 10,000 meters, with a maximum of 20,000 meters.
groundSpeed |
altitude_min |
altitude_max |
radius |
"latitude": 48.8588,
"longitude": 2.2943,
"altitude": 1200,
"groundSpeed": 30,
"course": 180,
"id": "XYZ789",
"latitude": 48.859,
"longitude": 2.293,
"altitude": 1500,
or visit our website.
Disclaimer
