Getting started
SafeSkyGetting API Guide
Started
The SafeSky API is accessible via a standard REST API, ensuringenabling easyseamless integration with your applications. FollowTo thesestart stepsusing tothe get started:API:
1.
Obtain-
Get an API Key
:Get an API Key
Visit SafeSky and subscribe to the plandesired that suits your needs.plan.
2.
Make API RequestsCalls:
Use the provided endpoints withprovided, including the necessaryappropriate parameters in your requests. All responses are deliveredreturned in JSON format.
3.
Authentication:
Authentication is automatically managed when making requests are made with your API key.
Important: KeepNever disclose your API key confidential and implementtake all standardnecessary security measures to protect it.
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
altitude_min |
altitude_max |
radius |
"id": "ABC123",
"latitude": 48.859,
"longitude": 2.293,
"altitude": 1500,
"status": "AIRBORNE"
"id": "DEF456",
"latitude": 48.860,
"longitude": 2.295,
"altitude": 2000,
Endpoint: POST /uav
Description:
Publish the UAV’s position, altitude, and flight status to the SafeSky platform while retrieving nearby traffic data within the specified radius. By default, the search radius is 10,000 meters, with a maximum of 20,000 meters.
groundSpeed |
altitude_min |
altitude_max |
radius |
"latitude": 48.8588,
"longitude": 2.2943,
"altitude": 1200,
"groundSpeed": 30,
"course": 180,
"id": "XYZ789",
"latitude": 48.859,
"longitude": 2.293,
"altitude": 1500,
or visit our website.
Disclaimer
