Getting started
SafeSky API Guide
The SafeSky API is accessible via a standard REST API, ensuring easy integration with your applications. Follow these steps to get started:
1. Obtain an API Key
Visit SafeSky and subscribe to the plan that suits your needs.
2. Make API Requests
Use the provided endpoints with the necessary parameters in your requests. All responses are delivered in JSON format.
3. Authentication
Authentication is automatically managed when requests are made with your API key.
Important: Keep your API key confidential and implement all standard security measures to protect it.
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
latitude double Yes Latitude in decimal degrees (4 decimal precision). N/A
longitude double Yes Longitude in decimal degrees (4 decimal precision). N/A
altitude_min int No Filter all aircraft below the given altitude in meters. Zero means 'unused'. 0
altitude_max int No Filter all aircraft above the given altitude in meters. Zero means 'unused'. 0
radius int No Radius in meters from the reference point (maximum: 20,000 meters). 10,000
    "id": "ABC123",
    "latitude": 48.859,
    "longitude": 2.293,
    "altitude": 1500,
    "status": "AIRBORNE"
    "id": "DEF456",
    "latitude": 48.860,
    "longitude": 2.295,
    "altitude": 2000,
Endpoint: POST /uav
Description:
Publish the UAV’s position, altitude, and flight status to the SafeSky platform while retrieving nearby traffic data within the specified radius. By default, the search radius is 10,000 meters, with a maximum of 20,000 meters.
  "latitude": 48.8588,
  "longitude": 2.2943,
  "altitude": 1200,
  "groundSpeed": 30,
  "course": 180,
    "id": "XYZ789",
    "latitude": 48.859,
    "longitude": 2.293,
    "altitude": 1500,
Disclaimer
