Getting started
The SafeSky API is available through standard REST API, allowing seamless integration into your applications. To begin using the API:
  1. Get an API key:
  2. Make API Calls:
    Use the endpoints below with appropriate parameters in your requests. All responses are returned in JSON format.
  3. Authentication:
    SafeSky API automatically handles authentication when you make requests using your API key.
Endpoints Overview
1. Get Nearby Aircraft
Endpoint: GET /uav
Description:
latitude double Yes Latitude in decimal degrees (4 decimal precision). N/A
longitude double Yes Longitude in decimal degrees (4 decimal precision). N/A
altitude_min int No Filter all aircraft below the given altitude in meters. Zero means 'unused'. 0
altitude_max int No Filter all aircraft above the given altitude in meters. Zero means 'unused'. 0
radius int No Radius in meters from the reference point (maximum: 20,000 meters). 10,000
    "id": "ABC123",
    "latitude": 48.859,
    "longitude": 2.293,
    "altitude": 1500,
    "status": "AIRBORNE"
    "id": "DEF456",
    "latitude": 48.860,
    "longitude": 2.295,
    "altitude": 2000,
Endpoint: POST /uav
Description:
Publish the UAV’s position, altitude, and flight status to the SafeSky platform while retrieving nearby traffic data within the specified radius. By default, the search radius is 10,000 meters, with a maximum of 20,000 meters.
  "latitude": 48.8588,
  "longitude": 2.2943,
  "altitude": 1200,
  "groundSpeed": 30,
  "course": 180,
    "id": "XYZ789",
    "latitude": 48.859,
    "longitude": 2.293,
    "altitude": 1500,
Disclaimer
