Firmware Changelog
1.6.1 - 04/11/2026
  • Fixed: your own aircraft could appear as traffic and trigger a false proximity alert in the app
  • Fixed: speed and course could disappear from the app over Bluetooth when many aircraft were around
  • Fixed: one slow Bluetooth device (e.g. a Garmin watch) could hold up your other connected devices
  • Fixed: the SafeSky app now receives the correct number of aircraft seen through SafeSky
  • Improved: should reduce duplicate aircraft near the newer radars
Updated the radio software
1.6.0 - 08/09/2026
  • Fixed issue with PowerOff button
  • Fixed issue when connecting several devices over BlueTooth
1.4.0 - 02/06/2026
1.2.0 - 31/07/2025
  • Added Mode-S reception support
  • Added FLARM reception support
1.0.4
  • Increased maximum number of aircraft over NMEA to 30
  • Added LTE and air-to-air total traffic counts to SafeSky status information
  • When processing an ADS-L packet (meant for ADS-L uplink), check the timestamp and drop packets with timestamps in the past
  • Added number of aircraft on the ESP32 list to the ADS-B log output
  • Sped up LTE modem repower in case of persistent UDP send errors
  • Provided a reset to default settings by keeping the button pressed after power-on
  • Corrected the bug in suppressing own ADS-B positions which created a ghost
1.0.2
  • Added ability to upload syslogs to SafeSky App
  • Added BLT/reset to restore factory settings without any salt validation
  • Send status to Avionix server
  • SafeSky reset now calls nvs_flash_erase to reset to factory settings
  • Added parameter to add 'sy' to callsigns from SafeSky traffic
  • Excluded own address from NMEA and GDL90
  • Added options for Wi-Fi mode: Access Point or Client mode with SSID and password
  • Removed unused Wi-Fi handlers
  • Removed "Emnify" from the LTE network name
  • Changed order of service registration for BLE advertisement
1.0.1
  • Initial public release
