Firmware Changelog
1.6.1 - 04/11/2026
- Fixed: your own aircraft could appear as traffic and trigger a false proximity alert in the app
- Fixed: speed and course could disappear from the app over Bluetooth when many aircraft were around
- Fixed: one slow Bluetooth device (e.g. a Garmin watch) could hold up your other connected devices
- Fixed: the SafeSky app now receives the correct number of aircraft seen through SafeSky
- Improved: should reduce duplicate aircraft near the newer radars
1.6.0 - 08/09/2026
- Fixed issue with PowerOff button
- Fixed issue when connecting several devices over BlueTooth
1.4.0 - 02/06/2026
- Added StarLink support
- Fixed problems when saving preferences
- Fixed issues with the power button
- Fixed callsigns for SkyDemon
- Improved FLARM reception
- Improved overall performance
1.2.0 - 31/07/2025
- Added Mode-S reception support
- Added FLARM reception support
1.0.4
- Increased maximum number of aircraft over NMEA to 30
- Added LTE and air-to-air total traffic counts to SafeSky status
information
- When processing an ADS-L packet (meant for ADS-L uplink), check the
timestamp and drop packets with timestamps in the past
- Added number of aircraft on the ESP32 list to the ADS-B log output
- Sped up LTE modem repower in case of persistent UDP send errors
- Provided a reset to default settings by keeping the button pressed
after power-on
- Corrected the bug in suppressing own ADS-B positions which created a
ghost
1.0.2
- Added ability to upload syslogs to SafeSky App
- Added BLT/reset to restore factory settings without any salt
validation
- Send status to Avionix server
- SafeSky reset now calls nvs_flash_erase to reset to factory settings
- Added parameter to add 'sy' to callsigns from SafeSky traffic
- Excluded own address from NMEA and GDL90
- Added options for Wi-Fi mode: Access Point or Client mode with SSID
and password
- Removed unused Wi-Fi handlers
- Removed "Emnify" from the LTE network name
- Changed order of service registration for BLE advertisement
1.0.1
