Firmware Change Log
Aero Tracker Firmware Changelog
1.6.0 - 08/09/2026
Fixed issue with PowerOff button
Fixed issue when connecting several devices over BlueTooth
1.4.0 - 02/06/2026
Added StarLink support
Fixed problems when saving preferences
Fixed issues with the power button
Fixed callsigns for SkyDemon
Improved FLARM reception
Improved overall performance
1.2.0 - 31/07/2025
Added Mode-S reception support
Added FLARM reception support
1.0.4
Increased maximum number of aircraft over NMEA to 30
Added LTE and air-to-air total traffic counts to SafeSky status
information
When processing an ADS-L packet (meant for ADS-L uplink), check the
timestamp and drop packets with timestamps in the past
Added number of aircraft on the ESP32 list to the ADS-B log output
Sped up LTE modem repower in case of persistent UDP send errors
Provided a reset to default settings by keeping the button pressed
after power-on
Corrected the bug in suppressing own ADS-B positions which created a
ghost
1.0.2
Added ability to upload syslogs to SafeSky App
Added BLT/reset to restore factory settings without any salt
validation
Send status to Avionix server
SafeSky reset now calls nvs_flash_erase to reset to factory settings
Added parameter to add 'sy' to callsigns from SafeSky traffic
Excluded own address from NMEA and GDL90
Added options for Wi-Fi mode: Access Point or Client mode with SSID
and password
Removed unused Wi-Fi handlers
Removed "Emnify" from the LTE network name
Changed order of service registration for BLE advertisement
1.0.1
Initial public release
