3 - Connect to your navigation software
1 - SkyDemon
2 - Other Navigation Software
Steps to Connect:
  1. Ensure your Aero Tracker is in Wi-Fi mode.
  2. Connect your phone or tablet to the Aero Tracker’s Wi-Fi hotspot.
  3. In your navigation software, configure the traffic source to GDL90.
  1. Open the SafeSky App and navigate to "My Devices".
  2. In the "External Devices" section, ensure your Aero Tracker shows a connected status via Bluetooth.
  3. Use the dropdown menu to view your configured aircraft in SafeSky.
  4. Select the desired aircraft from the list to update your Aero Tracker identity.
