2 - What traffic will I see?
đź§­ Using the Aero Tracker with an EFB
While air-to-air protocols (ADS-B, FLARM, Mode-S, ADS-L, FANET, OGN-Tracker) provide unfiltered traffic data, traffic received via the SafeSky LTE network is subject to the following filtering rules:
  • Vertical range: ±3000 feet from your current altitude
  • Horizontal range: 20 Nautical Miles around your position
  • Limit: To optimise LTE data flow, a maximum of 10 nearby aircraft will be presented to your EFB. These will always be aircraft that are closest to you.
📱 Using the SafeSky App
  • Displays more aircraft, including distant ones depending on filter settings
  • Combines traffic received via air-to-air, Aero Tracker LTE, and your device’s own LTE (provided your device has a SIM card)
  • Ideal for reviewing activity before takeoff, or maintaining general awareness in-flight
  • Traffic from the SafeSky LTE network appears with a sy prefix in the callsign
  • Air-to-air traffic keeps its standard callsign with no prefix
  1. Turn ON your Aero Tracker
  2. Open the SafeSky App
  3. Go to External Traffic
  4. Select your Aero Tracker from the list
  5. Tap Configure, then enable "Highlight SafeSky traffic"
📡 Mode-S trafficTraffic receptionReception
Mode-S transponders are not connected to a GPS system. They therefore do not transmit GPS-based position information. As a position.result, Thethey cannot provide precise latitude and longitude data. However, the Aero-Tracker ismeasures mesuringthe strength of the Mode-S signal to determine in a fairly accurateestimate the distance frombetween youyour aircraft and the Mode-SS–equipped aircraft.aircraft with reasonable accuracy.
1 -– SafeSky App
In SafeSky, Mode-S traffic willis displayed differently from GPS-positioned aircraft:
    It does not appear on the radar view, butdue willto appearthe lack of positional data. Instead, Mode-S traiifc is shown as aon-screen popuppop-ups onwhen thedetected screen:nearby.
    Only
    2 - SkyDemon
    First, make sure that under "Navigation Options", the option "Show Bearingless Targets" is turned on.
    Then, from SkyDemon,one Mode-S traffic at a time will appeartrigger a warning popup. This traffic will always be the closest to your position.
    SafeSky Mode-S pop-up
    2 – SkyDemon
    To visualise Mode-S traffic in SkyDemon, you need to configure this first:
      Go to Navigation Options. Ensure “Show Bearingless Targets” is enabled.
      Enable bearingless targets
      Once enabled, Mode-S aircraft will be displayed as acircles circlearound your position, indicating thetheir approximate distance from you and the aircraft..
      SkyDemon Mode-S traffic
      3 -– Other navigationNavigation software
      Software
      OtherCurrently, ForeFlight, Air Navigation, and similar navigation softwaretools such as ForeFlight or Air Navigation do not support bearingless targettraffic, atmeaning thisMode-S stage.aircraft will not be displayed in these applications.
      • After 10 minutes of no altitude or speed changes, it stops sending and receiving data to the SafeSky network
      • Air-to-air transmissions remain active, so others can still detect you
      • Once airborne, full functionality resumes automatically
      âś… Summary
      Scenario Traffic Displayed
      SafeSky App only All known traffic, including distant aircraft (when LTE is available)
      EFB only (via Aero Tracker Bluetooth) Nearby traffic only (±3000 ft, 20 NM), filtered and sorted by proximity
      Aero Tracker + SafeSky App Combined view: EFB shows nearby traffic, SafeSky App shows extended awareness
      Tracker grounded No network transmission after 10 minutes of inactivity, but air-to-air signals are still transmitted
