2 - What traffic will I see?
đź§ Using the Aero Tracker with an EFB
While air-to-air protocols (ADS-B, FLARM, Mode-S, ADS-L, FANET, OGN-Tracker) provide unfiltered traffic data, traffic received via the SafeSky LTE network is subject to the following filtering rules:
- Vertical range: ±3000 feet from your current altitude
- Limit: To optimise LTE data flow, a maximum of 10 nearby aircraft will be presented to your EFB. These will always be aircraft that are closest to you.
📱 Using the SafeSky App
- Turn ON your Aero Tracker
- Open the SafeSky App
- Go to External Traffic
📡 Mode-S Traffic Reception
Mode-S transponders do not transmit GPS-based position information. As a result, they cannot provide precise latitude and longitude data. However, the Aero-Tracker measures the strength of the Mode-S signal to estimate the distance between your aircraft and the Mode-S–equipped aircraft with reasonable accuracy.
1 – SafeSky App
In SafeSky, Mode-S traffic is displayed differently from GPS-positioned aircraft:
- It does not appear on the radar view, due to the lack of positional data.
- Instead, Mode-S traiifc is shown as on-screen pop-ups when detected nearby.
- Only one Mode-S traffic at a time will trigger a warning popup. This traffic will always be the closest to your position.
2 – SkyDemon
To visualise Mode-S traffic in SkyDemon, you need to configure this first:
Once enabled, Mode-S aircraft will be displayed as circles around your position, indicating their approximate distance.
3 – Other Navigation Software
Currently, ForeFlight, Air Navigation, and similar navigation tools do not support bearingless traffic, meaning Mode-S aircraft will not be displayed in these applications.
âś… Summary
| EFB only (via Aero Tracker Bluetooth) | Nearby traffic only (±3000 ft, 20 NM), filtered and sorted by proximity |
