2 - What traffic will I see?
While air-to-air protocols (ADS-B, FLARM, Mode-S, ADS-L, FANET, OGN-Tracker) provide unfiltered traffic data, traffic received via the SafeSky LTE network is subject to the following filtering rules:
- Vertical range: ±3000 feet from your current altitude
- Limit: To optimise LTE data flow, a maximum of 10 nearby aircraft will be presented to your EFB. These will always be aircraft that are closest to you.
📱 Using the SafeSky App
- Turn ON your Aero Tracker
- Open the SafeSky App
- Go to External Traffic
Mode-S traffic reception
Mode-S transponders are not connected to a GPS system. They therefore do not transmit a position. The Aero-Tracker is mesuring the Mode-S signal to determine in a fairly accurate the distance from you and the Mode-S aircraft.
1 - SafeSky App
In SafeSky, Mode-S traffic will not appear on the radar view, but will appear as a popup on the screen:
2 - SkyDemon
First, make sure that under "Navigation Options", the option "Show Bearingless Targets" is turned on.
Then, from SkyDemon, Mode-S traffic will appear as a circle indicating the approximate distance from you and the aircraft.
✅ Summary
| EFB only (via Aero Tracker Bluetooth) | Nearby traffic only (±3000 ft, 20 NM), filtered and sorted by proximity |
