2 - What traffic will I see?
While air-to-air protocols (ADS-B, FLARM, Mode-S, ADS-L, FANET, OGN-Tracker) provide unfiltered traffic data, traffic received via the SafeSky LTE network is subject to the following filtering rules:
  • Vertical range: ±3000 feet from your current altitude
  • Horizontal range: 20 Nautical Miles around your position
  • Limit: To optimise LTE data flow, a maximum of 10 nearby aircraft will be presented to your EFB. These will always be aircraft that are closest to you.
📱 Using the SafeSky App
  • Displays more aircraft, including distant ones depending on filter settings
  • Combines traffic received via air-to-air, Aero Tracker LTE, and your device’s own LTE (provided your device has a SIM card)
  • Ideal for reviewing activity before takeoff, or maintaining general awareness in-flight
  • Traffic from the SafeSky LTE network appears with a sy prefix in the callsign
  • Air-to-air traffic keeps its standard callsign with no prefix
  1. Turn ON your Aero Tracker
  2. Open the SafeSky App
  3. Go to External Traffic
  4. Select your Aero Tracker from the list
  5. Tap Configure, then enable "Highlight SafeSky traffic"
  • After 10 minutes of no altitude or speed changes, it stops sending and receiving data to the SafeSky network
  • Air-to-air transmissions remain active, so others can still detect you
  • Once airborne, full functionality resumes automatically
✅ Summary
Scenario Traffic Displayed
SafeSky App only All known traffic, including distant aircraft (when LTE is available)
EFB only (via Aero Tracker Bluetooth) Nearby traffic only (±3000 ft, 20 NM), filtered and sorted by proximity
Aero Tracker + SafeSky App Combined view: EFB shows nearby traffic, SafeSky App shows extended awareness
Tracker grounded No network transmission after 10 minutes of inactivity, but air-to-air signals are still transmitted
