2 - What traffic will I see?
This ensures your EFB displays only relevant, nearby traffic, letting you stay focused on essential information.screen.
This filtering is applied regardless of the traffic source, whether it's fromWhile air-to-air protocols (ADS-B, ADS-L, FANET, OGN-Tracker) orprovide unfiltered traffic data, traffic received via the SafeSky LTE network. is subject to the following filtering rules:
🛠️ Tip: Your
EFBnavigationmightapp may apply its own additional filters.MakeWesurerecommendto checkreviewing yourappEFB settings toalignensurewiththey match your operational preferences.
📱 Using the SafeSky App
- Turn ON your Aero Tracker
- Open the SafeSky App
- Go to External Traffic
✅ Summary
