2 - What traffic will I see?
While air-to-air protocols (ADS-B, ADS-L, FANET, OGN-Tracker) provide unfiltered traffic data, traffic received via the SafeSky LTE network is subject to the following filtering rules:
- Vertical range: ±2500 feet from your current altitude
- Priority: Closest traffic is prioritised to ensure the most relevant alerts
- Limit: A maximum of 10 nearby aircraft are displayed
📱 Using the SafeSky App
- Turn ON your Aero Tracker
- Open the SafeSky App
- Go to External Traffic
✅ Summary
