2 - What traffic will I see?
  • Vertical range: ±2500 feet
  • Horizontal range: 20 Nautical Miles
  • Sorting: Ordered by distance from your current position
📱 Using the SafeSky App
  • Displays more aircraft, including distant ones depending on filter settings
  • Combines traffic received via air-to-air, Aero Tracker LTE, and your device’s own LTE
  • Ideal for reviewing activity before takeoff, or maintaining general awareness in-flight
  • Traffic from the SafeSky LTE network appears with a sy prefix in the callsign
  • Air-to-air traffic keeps its standard callsign with no prefix
  1. Turn ON your Aero Tracker
  2. Open the SafeSky App
  3. Go to External Traffic
  4. Select your Aero Tracker from the list
  5. Tap Configure, then enable "Highlight SafeSky traffic"
  • After 10 minutes of no altitude or speed changes, it stops sending and receiving data to the SafeSky network
  • Air-to-air transmissions remain active, so others can still detect you
  • Once airborne, full functionality resumes automatically
✅ Summary
Scenario Traffic Displayed
SafeSky App only All known traffic, including distant aircraft (when LTE is available)
EFB only (via Aero Tracker Bluetooth) Nearby traffic only (±2500 ft, 20 NM), filtered and sorted by proximity
Aero Tracker + SafeSky App Combined view: EFB shows nearby traffic, SafeSky App shows extended awareness
Tracker grounded No network transmission, but air-to-air signals are still transmitted
