2 - What Traffic Will I See?
- Vertical range: ±2500 feet
📱 Using the SafeSky App
- Turn ON your Aero Tracker
- Open the SafeSky App
- Go to External Traffic
✅ Summary
| Tracker grounded | No network transmission, but air-to-air signals are still transmitted |
