2 - What Traffic Will I See?
- Vertical range: ±2500 feet
📱 Using the SafeSky App
sy
prefix in the callsign - Air-to-air traffic keeps its standard callsign with no prefix
- Turn ON your Aero Tracker
- Open the SafeSky App
- Go to External Traffic
✅ Summary
Scenario | Traffic Displayed |
SafeSky App only | All known traffic, including distant aircraft (when LTE is available) |
EFB only (via Aero Tracker Bluetooth) | Nearby traffic only (±2500 ft, 20 NM), filtered and sorted by proximity |
Aero Tracker + SafeSky App | Combined view: EFB shows nearby traffic, SafeSky App shows extended awareness |
Tracker grounded | No network transmission, but air-to-air signals are still transmitted |
