2 - What Traffic Will I See?
- Vertical range: ±2500 feet
📱 Using the SafeSky App
- Turn ON your Aero Tracker
- Open the SafeSky App
- Go to External Traffic
- After 10 minutes of no altitude or speed changes, it stops sending data to the SafeSky network
✅ Summary
| Tracker grounded | No network transmission, but air-to-air signals are still transmitted |
