2 - What Traffic Will I See?
Understanding the traffic displayed by your Aero Tracker depends on how you're using it—either through the SafeSky App or an Electronic Flight Bag (EFB) such as SkyDemon, Air Navigation Pro, or EasyVFR. Each setup provides a tailored experience to balance clarity and situational awareness.
- Vertical range: ±2500 feet
This filtering is applied regardless of the traffic source—whether it's from air-to-air protocols (ADS-B, ADS-L, FANET, OGN-Tracker) or via the SafeSky LTE network.
📱 Using the SafeSky App
sy
prefix in the callsign - Air-to-air traffic keeps its standard callsign with no prefix
- Turn ON your Aero Tracker
- Open the SafeSky App
- Go to External Traffic
- After 10 minutes of no altitude or speed changes, it stops sending data to the SafeSky network
✅ Summary
Scenario | Traffic Displayed |
SafeSky App only | All known traffic, including distant aircraft (when LTE is available) |
EFB only (via Aero Tracker Bluetooth) | Nearby traffic only (±2500 ft, 20 NM), filtered and sorted by proximity |
Aero Tracker + SafeSky App | Combined view: EFB shows nearby traffic, SafeSky App shows extended awareness |
Tracker grounded | No network transmission, but air-to-air signals are still transmitted |
