4 - Connect to your navigation software
SkyDemon
You can now take advantage of the latest NMEA over Bluetooth feature for seamless integration.
Other Navigation Software
If you've previously used SafeSky with GDL90 on your favourite navigation software, the process remains the same, except that the aero-tracker now replaces your phone running SafeSky.
Steps to Connect:
  1. Ensure your aero-tracker is in Wi-Fi mode.
  2. Connect your phone or tablet to the aero-tracker’s Wi-Fi hotspot.
  3. In your navigation software, configure it to use GDL90.
✅ You should now see both SafeSky and air-to-air traffic directly on your navigation software.
Change Aero-Tracker Aircraft Identity
  1. Ensure your aero-tracker is in Bluetooth mode.
  2. Open the SafeSky App and navigate to "My Devices".
  3. In the dropdown menu, you’ll see a list of aircraft configured in SafeSky.
  4. Simply select the desired aircraft from the dropdown to change your aero-tracker identity.
✅ Your aero-tracker is now assigned to the selected aircraft. Note this is a temporary flow.
